Estimation de mélange de Gaussiennes sur données compressées
Estimating a probability mixture model from a set of vectors typically requires a large amount of memory if the data is voluminous. We propose a framework where the data is jointly compressed to a fixed-size representation called sketch, composed of empirical moments calculated from the data. By analogy with compressive sensing, we derive a parameter estimation algorithm from the sketch. We experimentally show that our algorithm allows precise estimation while consuming less memory than an EM algorithm for voluminous data. The algorithm also provides a privacy-preserving estimation tool since the sketch does not disclose information about individual datum it is based on.
