Parallelization of a relaxation scheme modelling the bedload transport of sediments in shallow water flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Proceedings Année : 2013
In this work we are interested in numerical simulations for bedload erosion processes. We present a relaxation solver that we apply to moving dunes test cases in one and two dimensions. In particular we retrieve the so-called anti-dune process that is well described in the experiments. In order to be able to run 2D test cases with reasonable CPU time, we also describe and apply a parallelization procedure by using domain decomposition based on the classical MPI library.
Audusse-et-al2012.pdf (883.48 Ko) Télécharger le fichier
As01.avi (3.28 Mo) Télécharger le fichier
As01_contour.avi (7.24 Mo) Télécharger le fichier
anim2.avi (1.9 Mo) Télécharger le fichier
anim_contour.avi (4.27 Mo) Télécharger le fichier
antidune_1D.avi (4.56 Mo) Télécharger le fichier
Format : Vidéo
Format : Vidéo
Format : Vidéo
Format : Vidéo
Format : Vidéo
hal-00840200 , version 1 (01-07-2013)
Emmanuel Audusse, Olivier Delestre, Le Minh-Hoang, Mathias Masson-Fauchier, Pierre Navaro, et al.. Parallelization of a relaxation scheme modelling the bedload transport of sediments in shallow water flow. ESAIM: Proceedings, 2013, 43, pp.80-94. ⟨10.1051/proc/201343005⟩. ⟨hal-00840200⟩
618 Consultations
199 Téléchargements
