Some Synchronization Issues in OSPF Routing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A routing protocol such as OSPF has a cyclic behavior to regularly update its view of the network topology. Its behavior is divided into periods. Each period produces a flood of network information messages. We observe a regular activity in terms of messages exchanges and fi lling of receive bu ffers in routers. This article examines the consequences of possible overlap of activity between periods, leading to a buff er overflow. OSPF allows "out of sync" flows by considering an initial delay (phase). We study the optimum calculation of these off sets to reduce the load, while maintaining a short period to ensure a protocol reactive to topology changes. Such studies are conducted using a simulated Petri net model. A heuristic for determining initial delays is proposed. A core network in Germany serves as illustration.
DCNet_camera_ready.pdf (362.02 Ko) Télécharger le fichier
hal-00840350 , version 1 (04-07-2013)
  • HAL Id : hal-00840350 , version 1
Anne Bouillard, Claude Jard, Aurore Junier. Some Synchronization Issues in OSPF Routing. DCNET13: the 4th International Conference on Data Communication Networking,, Jul 2013, Reykjavik, Iceland. pp.5-14. ⟨hal-00840350⟩
504 Consultations
143 Téléchargements
