Correlation effect between transmitter and receiver azimuthal directions on the illumination function from a random rough surface - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Waves in Random and Complex Media Année : 2013
The resolution of some problems of electromagnetic scattering from random rough surfaces implies the derivation of the illumination function, especially when the geometrical optics approximation is valid. In current models, the shadowing e ects occurring for both the trans- mitter and the receiver are assumed to be independent of their azimuthal directions. This assumption makes it possible to compute separately the shadowing probabilities in each di- rection. However, if the transmitter and receiver azimuthal directions are close, these proba- bilities become strongly correlated. In such a con guration, the uncorrelation approximation induces an overestimation of the average illumination function up to 10% as well as a discon- tinuity. In this paper, assuming a surface with Gaussian process, this correlation is taken into account. Comparisons of our model with Monte Carlo simulations are made and show a very good agreement, which validates our approach.
Mots clés
2013_WRCM_pre_print_Heitz_et_al.pdf (373.36 Ko) Télécharger le fichier
hal-00840796 , version 1 (26-08-2013)
Eric Heitz, Christophe Bourlier, Nicolas Pinel. Correlation effect between transmitter and receiver azimuthal directions on the illumination function from a random rough surface. Waves in Random and Complex Media, 2013, 23 (3), pp.318-335. ⟨10.1080/17455030.2013.822611⟩. ⟨hal-00840796⟩
1022 Consultations
783 Téléchargements
