An MsFEM type approach for perforated domains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Multiscale Modeling and Simulation: A SIAM Interdisciplinary Journal Année : 2014
We follow up on our previous work [C. Le Bris, F. Legoll and A. Lozinski, Chinese Annals of Mathematics 2013] where we have studied a multiscale finite element (MsFEM) type method in the vein of the classical Crouzeix-Raviart finite element method that is specifically adapted for highly oscillatory elliptic problems. We adapt the approach to address here a multiscale problem on a perforated domain. An additional ingredient of our approach is the enrichment of the multiscale finite element space using bubble functions. We first establish a theoretical error estimate. We next show that, on the problem we consider, the approach we propose outperforms all dedicated existing variants of MsFEM we are aware of.
hal-00841308 , version 1 (04-07-2013)
Claude Le Bris, Frédéric Legoll, Alexei Lozinski. An MsFEM type approach for perforated domains. Multiscale Modeling and Simulation: A SIAM Interdisciplinary Journal, 2014, 12 (3), pp.1046-1077. ⟨10.1137/130927826⟩. ⟨hal-00841308⟩
401 Consultations
0 Téléchargements
