Efficient nonlinear FEM for soft tissue modelling and its GPU implementation within the open source framework SOFA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Accurate biomechanical modelling of soft tissue is a key aspect for achieving realistic surgical simulations. However, because medical simulation is a multi-disciplinary area, researchers do not always have sufficient resources to develop an efficient and physically rigorous model for organ deformation. We address this issue by implementing a CUDA-based nonlinear finite element model into the SOFA open source framework. The proposed model is an anisotropic visco-hyperelastic constitutive formulation implemented on a graphical processor unit (GPU). After presenting results on the model's performance we illustrate the benefits of its integration within the SOFA framework on a simulation of cataract surgery.
hal-00841568 , version 1 (05-07-2013)
Olivier Comas, Zeike A Taylor, Jérémie Allard, Sébastien Ourselin, Stéphane Cotin, et al.. Efficient nonlinear FEM for soft tissue modelling and its GPU implementation within the open source framework SOFA. ISBMS 2008 - 4th International Symposium on Biomedical Simulation, Jul 2008, London, United Kingdom. pp.28-39, ⟨10.1007/978-3-540-70521-5_4⟩. ⟨hal-00841568⟩
205 Consultations
0 Téléchargements
