A regularized Newton method for the solution of an inverse obstacle scattering problem in fluid-solid interaction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fichier non déposé
hal-00842176 , version 1 (08-07-2013)
  • HAL Id : hal-00842176 , version 1
Hélène Barucq, Rabia Djellouli, Elodie Estecahandy. A regularized Newton method for the solution of an inverse obstacle scattering problem in fluid-solid interaction. COMPDYN 2013 - 4th International Conference on Computational Methods in Structural Dynamics and Earthquake Engineering - 2013, Jun 2013, Kos, Greece. ⟨hal-00842176⟩
117 Consultations
0 Téléchargements
