Equivalent Conditions for Elasto-Acoustics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present Equivalent Conditions (ECs) for the diffraction problem of elasto-acoustic waves in a solid medium surrounded by a thin region of fluid medium. This problem is well suited for the notion of ECs : since the thickness of the layer is small with respect to the wavelength, the effect of the fluid on the solid is as a first approximation local. These conditions approximate the acoustic waves which propagate in the fluid region. We present numerical results to illustrate the accuracy of ECs.
Waves2013.pdf (171.39 Ko) Télécharger le fichier
hal-00842571 , version 1 (17-03-2021)
  • HAL Id : hal-00842571 , version 1
Julien Diaz, Victor Péron. Equivalent Conditions for Elasto-Acoustics. Waves 2013 - 11th International Conference on Mathematical and Numerical Aspects of Waves, Jun 2013, Gammarth, Tunisia. pp.345-346. ⟨hal-00842571⟩
114 Consultations
103 Téléchargements
