Set Adaptive Observers for Linear Parameter-Varying Systems: Application to Fault Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Dynamic Systems, Measurement, and Control Année : 2014
This paper deals with the problem of joint state and parameter estimation based on a set adaptive observer design. The problem is formulated and solved for an LPV (Linear Parameter-Varying) system. The resolution methodology avoids the exponential complexity obstruction usually encountered in the set-membership parameter estimation. A simulation example is presented to illustrate the efficiency of the proposed approach.
Automatique
Interval_adaptive_observer.pdf (231.94 Ko) Télécharger le fichier
hal-00843639 , version 1 (11-07-2013)
Denis Efimov, Tarek Raissi, Ali Zolghadri. Set Adaptive Observers for Linear Parameter-Varying Systems: Application to Fault Detection. Journal of Dynamic Systems, Measurement, and Control, 2014, 136 (2), pp.7. ⟨10.1115/1.4025797⟩. ⟨hal-00843639⟩
235 Consultations
316 Téléchargements
