Noise-Adaptive Shape Reconstruction from Raw Point Sets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2013
Simon Giraudot
  • Fonction : Auteur
  • PersonId : 943620
David Cohen-Steiner
  • Fonction : Auteur
  • PersonId : 833472
Pierre Alliez
We propose a noise-adaptive shape reconstruction method specialized to smooth, closed shapes. Our algorithm takes as input a defect-laden point set with variable noise and outliers, and comprises three main steps. First, we compute a novel noise-adaptive distance function to the inferred shape, which relies on the assumption that the inferred shape is a smooth submanifold of known dimension. Second, we estimate the sign and confidence of the function at a set of seed points, through minimizing a quadratic energy expressed on the edges of a uniform random graph. Third, we compute a signed implicit function through a random walker approach with soft constraints chosen as the most confident seed points computed in previous step.
reconstruction2.pdf (399.81 Ko) Télécharger le fichier
Format : Figure, Image
hal-00844472 , version 1 (15-07-2013)
Simon Giraudot, David Cohen-Steiner, Pierre Alliez. Noise-Adaptive Shape Reconstruction from Raw Point Sets. Computer Graphics Forum, 2013, 32 (5), pp.229-238. ⟨10.1111/cgf.12189⟩. ⟨hal-00844472⟩
Collections
INRIA INRIA2
415 Consultations
3067 Téléchargements
