Convergence of time dependent Turing structure to a stationary solution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Acta Applicandae Mathematicae Année : 2013
Stability of stationary solutions of parabolic equations is conventionally studied by linear stability analysis, Lyapunov functions or lower and upper functions. We discuss here another approach based on differential inequalities written for the L 2 norm of the solution. This method is appropriate for the equations with time dependent coefficients. It yields new results and is applicable when the usual linearization method is not applicable.
hal-00846571 , version 1 (19-07-2013)
Vitaly Volpert, A.G. Ramm. Convergence of time dependent Turing structure to a stationary solution. Acta Applicandae Mathematicae, 2013, 123 (1), pp.31-42. ⟨10.1007/s10440-012-9711-5⟩. ⟨hal-00846571⟩
263 Consultations
0 Téléchargements
