Comparison bewteen multi-task and single-task oracle risks in kernel ridge regression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
In this paper we study multi-task kernel ridge regression and try to understand when the multi-task procedure performs better than the single-task one, in terms of averaged quadratic risk. In order to do so, we compare the risks of the estimators with perfect calibration, the \emph{oracle risk}. We are able to give explicit settings, favorable to the multi-task procedure, where the multi-task oracle performs better than the single-task one. In situations where the multi-task procedure is conjectured to perform badly, we also show the oracle does so. We then complete our study with simulated examples, where we can compare both oracle risks in more natural situations. A consequence of our result is that the multi-task ridge estimator has a lower risk than any single-task estimator, in favorable situations.
solnon_comparison.pdf (489.06 Ko) Télécharger le fichier
hal-00846715 , version 1 (19-07-2013)
Matthieu Solnon. Comparison bewteen multi-task and single-task oracle risks in kernel ridge regression. 2013. ⟨hal-00846715⟩
173 Consultations
103 Téléchargements
