Introducing a simple fusion framework for audio source separation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose in this paper a simple fusion framework for underdetermined audio source separation. This framework can be applied to a wide variety of source separation algorithms providing that they estimate time-frequency masks. Fusion principles have been successfully implemented for classification tasks. Although it is similar to classification, audio source separation does not usually take advantage of such principles. We thus introduce some general fusion rules inspired by classification and we evaluate them in the context of voice extraction. Experimental results are promising as our proposed fusion rule can improve separation results up to 1 dB in SDR.
mlsp2013_vHal.pdf (236.08 Ko) Télécharger le fichier
hal-00846834 , version 1 (21-07-2013)
  • HAL Id : hal-00846834 , version 1
Xabier Jaureguiberry, Gael Richard, Pierre Leveau, Romain Hennequin, Emmanuel Vincent. Introducing a simple fusion framework for audio source separation. 2013 IEEE International Workshop on Machine Learning for Signal Processing, Sep 2013, Southampton, United Kingdom. pp.6. ⟨hal-00846834⟩
465 Consultations
348 Téléchargements
