From variable density sampling to continuous sampling using Markov chains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Since its discovery over the last decade, Compressed Sensing (CS) has been successfully applied to Magnetic Resonance Imaging (MRI). It has been shown to be a powerful way to reduce scanning time without sacrificing image quality. MR images are actually strongly compressible in a wavelet basis, the latter being largely incoherent with the k-space or spatial Fourier domain where acquisition is performed. Nevertheless, since its first application to MRI [1], the theoretical justification of actual k-space sampling strategies is questionable. Indeed, the vast majority of k-space sampling distributions have been heuris- tically designed (e.g., variable density) or driven by experimental feasibility considerations (e.g., random radial or spiral sampling to achieve smoothness k-space trajectory). In this paper, we try to reconcile very recent CS results with the MRI specificities (magnetic field gradients) by enforcing the measurements, i.e. samples of k-space, to fit continuous trajectories. To this end, we propose random walk continuous sampling based on Markov chains and we compare the reconstruction quality of this scheme to the state-of-the art.
markov_sampling_Sampta.pdf (541.76 Ko) Télécharger le fichier
hal-00848286 , version 1 (26-07-2013)
Nicolas Chauffert, Philippe Ciuciu, Pierre Weiss, Fabrice Gamboa. From variable density sampling to continuous sampling using Markov chains. SampTA - 10th Conference International Conference on Sampling Theory and Applications, Jul 2013, Bremen, Germany. pp.200-203. ⟨hal-00848286⟩
295 Consultations
103 Téléchargements
