Probing a Continuum of Macro-molecular Assembly Models with Graph Templates of Sub-complexes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proteins - Structure, Function and Bioinformatics Année : 2013
Valérie Doye
Frédéric Cazals
Reconstruction by data integration is an emerging trend to reconstruct large protein assemblies, but uncertainties on the input data yield average models whose quantitative interpretation is challenging. This article presents methods to probe fuzzy models of large assemblies against atomic resolution models of subsystems. Consider a toleranced model (TOM) of a macromolecular assembly, namely a continuum of nested shapes representing the assembly at multiple scales. Also consider a template namely an atomic resolution 3D model of a subsystem (a complex) of this assembly. We present graph-based algorithms performing a multi-scale assessment of the complexes of the TOM, by comparing the pairwise contacts which appear in the TOM against those of the template. We apply this machinery on TOM derived from an average model of the Nuclear Pore Complex, to explore the connections among members of its well-characterized Y-complex.
hal-00849795 , version 1 (01-08-2013)
Tom Dreyfus, Valérie Doye, Frédéric Cazals. Probing a Continuum of Macro-molecular Assembly Models with Graph Templates of Sub-complexes. Proteins - Structure, Function and Bioinformatics, 2013, ⟨10.1002/prot.24313⟩. ⟨hal-00849795⟩
124 Consultations
0 Téléchargements
