An automated image-processing pipeline for high-throughput analysis of root architecture in OpenAlea - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Xavier Draye
  • Fonction : Auteur
  • PersonId : 866185
FSPM analysis of root systems requires structural data obtained on large data set. This paper describes a processing pipeline developed to extract automatically the architecture of root system from images databases.
DienierNacryPerinDievartDrayeBoundonGaujonGodin2013.pdf (511.15 Ko) Télécharger le fichier
poster.pdf (3.67 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
hal-00850814 , version 1 (08-08-2013)
  • HAL Id : hal-00850814 , version 1
  • PRODINRA : 385945
Julien Diener, Phillipe Nacry, Christophe Périn, Anne Diévart, Xavier Draye, et al.. An automated image-processing pipeline for high-throughput analysis of root architecture in OpenAlea. 7th International Conference on Functional-Structural Plant Models, Jun 2013, Saariselkä, Finland. pp.85-87. ⟨hal-00850814⟩
682 Consultations
2144 Téléchargements
