Characterizing the balance between ontogeny and environmental constraints in forest tree development using growth phase duration distributions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We built segmentation models to identify tree growth phases on the basis of retrospective measurement of annual shoot characteristics along the main stem. Growth phase duration distributions estimated within these models characterize the balance between ontogeny and environmental constraints in tree development at the population scale. These distributions have very contrasted characteristics in terms of shape and relative dispersion between ontogeny-driven and environment-driven tree development.
GuedonTaugourdeauCaraglioSabatier2013.pdf (57.11 Ko) Télécharger le fichier
hal-00850838 , version 1 (09-08-2013)
  • HAL Id : hal-00850838 , version 1
  • PRODINRA : 315331
Yann Guédon, Olivier Taugourdeau, Yves Caraglio, Sylvie Sabatier. Characterizing the balance between ontogeny and environmental constraints in forest tree development using growth phase duration distributions. 7th International Conference on Functional-Structural Plant Models, Jun 2013, Saariselkä, Finland. pp.237-239. ⟨hal-00850838⟩
256 Consultations
120 Téléchargements
