Re-parametrisation of Adel-wheat allows reducing the experimental effort to simulate the 3D development of winter wheat - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A parameterisation of wheat architecture was developed, having high flexibility to simulate contrasted genotypes and growth conditions with a reasonably low number of parameters. Field measurements at 4-5 dates allowed to simulate crops from emergence to maturity with a good agreement between simulated and measured ground cover and GAI. Dynamics of leaf angles were shown to impact strongly ground cover.
Abichou-FSPM2013_{6DD6F381-8861-414A-9776-D92372EA15F8}.pdf (133.99 Ko) Télécharger le fichier
hal-01512123 , version 1 (21-04-2017)
  • HAL Id : hal-01512123 , version 1
  • PRODINRA : 270273
Mariem Abichou, Christian Fournier, Tino Dornbusch, Camille Chambon, Rim Baccar, et al.. Re-parametrisation of Adel-wheat allows reducing the experimental effort to simulate the 3D development of winter wheat. 7. International Conference on Functional Structure Plant Models, Jun 2013, Saariselkä, Finland. ⟨hal-01512123⟩
738 Consultations
629 Téléchargements
