Convective heat transfer analysis in aggregates rotary drum reactor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Thermal Engineering Année : 2013
Heat transport characterisation inside rotary drum dryer has a considerable importance linked to the many industrial applications. The present paper deals with the heat transfer analysis from experimental apparatus installed in a large-scale rotary drum reactor applied to the asphalt materials production. The equipment including in-situ thermal probes and external visualization by mean infrared thermography gives rise to the longitudinal evaluation of inner and external temperatures. The assessment of the heat transfer coefficients by an inverse methodology is resolved in order to accomplish a fin analysis of the convective mechanism inside baffled (or flights) rotary drum. The results are discussed and compared with major results of the literature.
hal-00851501 , version 1 (14-08-2013)
Laurédan Le Guen, Florian Huchet, Jean Dumoulin, Philippe Tamagny. Convective heat transfer analysis in aggregates rotary drum reactor. Applied Thermal Engineering, 2013, 54 (1), pp 131-139. ⟨10.1016/j.applthermaleng.2013.01.025⟩. ⟨hal-00851501⟩
164 Consultations
0 Téléchargements
