A semi-Lagrangian discontinuous Galerkin convergence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
We show a superconvergence property for the Semi-Lagrangian Discontinuous Galerkin scheme of arbitrary degree in the case of constant linear advection equation with periodic boundary conditions.
SLDGsuperconv.pdf (437.7 Ko) Télécharger le fichier
hal-00852411 , version 1 (21-08-2013)
  • HAL Id : hal-00852411 , version 1
Christophe Steiner, Michel Mehrenberger, Daniel Bouche. A semi-Lagrangian discontinuous Galerkin convergence. 2013. ⟨hal-00852411⟩
331 Consultations
151 Téléchargements
