Analysis, simulation and impedance operator of a nonlocal model of porous medium for acoustic control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Vibration and Control Année : 2015
The problem under consideration relates to a model of a porous wall devoted to aircraft motor noise reduction. For such a medium, the parameters of the propagation equation depend on the frequency. Then, the associated time-model involves non rational convolution operators, which make the model complex from both analysis and simulation points of view. In this paper, based on the so-called di usive representation of con- volution operators, a time-local formulation of the porous wall model, well adapted to analysis and numerical simulation, is established and analyzed. Then its associated impedance operator is computed. Fi- nally, some numerical results relating to the time-domain simulation of the porous wall and its impedance operator are given.
Montseny_et_al._-_2013_-_Analysis_simulation_and_impedance_operator_of_a_non_local_model_of_porous_medium_for_acoustic_control.pdf (698.72 Ko) Télécharger le fichier
hal-00854312 , version 1 (26-08-2013)
Emmanuel Montseny, Céline Casenave. Analysis, simulation and impedance operator of a nonlocal model of porous medium for acoustic control. Journal of Vibration and Control, 2015, 21 (5), pp. 1012-1028. ⟨10.1177/1077546313493815⟩. ⟨hal-00854312⟩
394 Consultations
199 Téléchargements
