Kalman Filter for Process Noise Free Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The purpose of this paper is to study the stability properties of the Kalman filter applied to process noise free systems. Due to the absence of the process noise (also known as state noise), such a system cannot be controllable regarding the process noise. The stability of the Kalman filter is typically based on the boundedness of the error covariance matrix governed by a dynamic Riccati equation (DRE), which is usually ensured by the controllability regarding the process noise and by the observability. This classical result cannot be applied to the considered case because of the lack of controllability. It is shown in this paper that, under the observability condition, the solution of the DRE is bounded and converges to a solution of the algebraic Riccati equation (ARE), regardless of the stability of the considered system. In the case of asymptotically unstable systems, the solution of the ARE is not unique. In this case the relationship between the DRE and the ARE is clarified. It is also shown that the DRE based Kalman filter is always valid, whereas the ARE based Kalman filter cannot be applied when the process noise free system has marginally stable modes. A numerical example is presented to verify the correctness of the theoretical analysis.
Automatique
Fichier non déposé
hal-00854678 , version 1 (27-08-2013)
Boyi Ni, Qinghua Zhang. Kalman Filter for Process Noise Free Systems. 11th IFAC International Workshop on Adaptation and Learning in Control and Signal Processing, Jul 2013, Caen, France. pp.176-181, ⟨10.3182/20130703-3-FR-4038.00062⟩. ⟨hal-00854678⟩
Collections
INRIA INRIA2
171 Consultations
0 Téléchargements
