Decoding color codes by projection onto surface codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review A : Atomic, molecular, and optical physics [1990-2015] Année : 2014
We propose a new strategy to decode color codes, which is based on the projection of the error onto three surface codes. This provides a method to transform every decoding algorithm of surface codes into a decoding algorithm of color codes. Applying this idea to a family of hexagonal color codes, with the perfect matching decoding algorithm for the three corresponding surface codes, we find a phase error threshold of approximately 8.7%. Finally, our approach enables us to establish a general lower bound on the error threshold of a family of color codes depending on the threshold of the three corresponding surface codes. These results are based on a chain complex interpretation of surface codes and color codes.
color_decoding.pdf (432.8 Ko) Télécharger le fichier
hal-00855003 , version 1 (28-08-2013)
Nicolas Delfosse. Decoding color codes by projection onto surface codes. Physical Review A : Atomic, molecular, and optical physics [1990-2015], 2014, 89, pp.012317. ⟨10.1103/PhysRevA.89.012317⟩. ⟨hal-00855003⟩
197 Consultations
460 Téléchargements
