Dealing with constraints in sensor-based robot control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Robotics Année : 2014
A framework is presented in this paper for the control of a multi-sensor robot under several constraints. In this approach, the features coming from several sensors are treated as a single feature vector. The core of our approach is a weighting matrix that balances the contribution of each feature, allowing to take constraints into account. The constraints are considered as additional features that are smoothly injected in the control law. Multi-sensor modeling is introduced for the design of the control law, drawing similarities with linear quadratic control. The main properties are exposed and we propose several strategies to cope with the main drawbacks. The framework is validated on a complex experiment, illustrating various aspects of the approach. The goal is the positioning of a 6 DOF robot arm with 3D visual servoing. The considered constraints are both eye-in-hand and eye-to-hand visibility, together with joint limits avoidance. The system is thus highly overdetermined, yet the task can be performed while ensuring several combination of constraints.
2013_tro_kermorgant.pdf (2.67 Mo) Télécharger le fichier
hal-00855724 , version 1 (29-08-2013)
Olivier Kermorgant, François Chaumette. Dealing with constraints in sensor-based robot control. IEEE Transactions on Robotics, 2014, 30 (1), pp.244-257. ⟨10.1109/TRO.2013.2281560⟩. ⟨hal-00855724⟩
463 Consultations
683 Téléchargements
