Inverse problems in fluid-structure interaction: Application to hemodynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this talk we deal with the simulation of fluid-structure interaction (FSI) problems in hemodynamics, with the emphasis in data assimilation and simulation in physiological regimes.
Bertoglio_YIC2013.pdf (175.33 Ko) Télécharger le fichier
hal-00855837 , version 1 (30-08-2013)
  • HAL Id : hal-00855837 , version 1
Cristobal Bertoglio, Philippe Moireau, Jean-Frédéric Gerbeau, Miguel Angel Fernández, Dominique Chapelle, et al.. Inverse problems in fluid-structure interaction: Application to hemodynamics. 2nd ECCOMAS Young Investigators Conference (YIC 2013), Sep 2013, Bordeaux, France. ⟨hal-00855837⟩
1082 Consultations
386 Téléchargements
