Coupling two cell-centered finite volume schemes for solving anisotropic diffusion and fluid dynamics on unstructured moving meshes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In our work we intend to model the physical phenomenons occuring during the atmospheric re-entry of a spacecraft at a low altitude. We developped a cell-centered finite volume scheme for solving anisotropic diffusion on unstructured moving meshes in order to model the thermal transfers occuring in the re-entry vehicule. We also developped a cell-centered finite volume scheme for solving the Navier-Stokes equations in order to model the hypersonic fluid flow around the vehicle. In this talk we will focus on the modelisation of the ablation phenomenon which introduce a coupling between the flow and the thermal transfers.
YIC2013_jacq.pdf (161.89 Ko) Télécharger le fichier
hal-00855868 , version 1 (30-08-2013)
  • HAL Id : hal-00855868 , version 1
Pascal Jacq, P.H. Maire, Jean Claudel, Remi Abgrall. Coupling two cell-centered finite volume schemes for solving anisotropic diffusion and fluid dynamics on unstructured moving meshes. 2nd ECCOMAS Young Investigators Conference (YIC 2013), Sep 2013, Bordeaux, France. ⟨hal-00855868⟩
237 Consultations
244 Téléchargements
