Lagrangian sharp interface schemes for multimaterials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present multi-material simulations in the Lagrangian framework. The methods employed are based on classical Godunov-like methods that are adapted to treat the case of interfaces separating different materials.In the models considered the gas, liquids or elastic materials are described by specific constitutive laws, but the governing equations are the same. Examples of gas-gas and elastic-elastic material interactions are presented.
I2M_YIC_Milcent_2013.pdf (455.39 Ko) Télécharger le fichier
Format : typeAnnex_author
hal-01089300 , version 1 (01-12-2014)
  • HAL Id : hal-01089300 , version 1
  • ENSAM : http://hdl.handle.net/10985/9040
Thomas Milcent, Angelo Iollo. Lagrangian sharp interface schemes for multimaterials. ECCOMAS Young Investigators Conference (YIC 2013)(2;2013; Bordeaux), Sep 2013, Bordeaux, France. 4p. ⟨hal-01089300⟩
187 Consultations
62 Téléchargements
