A new framework for metabolic modeling under non-balanced growth. Application to carbon metabolism of unicellular microalgae - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Macroscopic and metabolic models are ubiquitous tools for bioprocess modeling and understanding. While these two modeling approaches bring answers to different objectives, a remaining challenging question is how to couple macroscopic and intracellular models to enlarge the prediction capabilities of the model while keeping a model structure with low complexity level? In this paper, we provide conceptual guidelines to address this question. We propose a new modeling framework that manages non-balanced growth condition and hence accumulation of intracellular metabolites. The first stage consists in determining metabolic sub-networks, which are assumed to satisfy balanced growth condition. Then, the remaining metabolites interconnecting the sub-networks can dynamically accumulate or be reused.
CAB2013_Baroukh_Caroline_revised_version_2_table_included.pdf (673.56 Ko) Télécharger le fichier
hal-00856042 , version 2 (30-08-2013)
hal-00856042 , version 1 (03-06-2020)
  • HAL Id : hal-00856042 , version 2
Caroline Baroukh, Rafael Munoz Tamayo, Jean-Philippe Steyer, Olivier Bernard. A new framework for metabolic modeling under non-balanced growth. Application to carbon metabolism of unicellular microalgae: Application to carbon metabolism of unicellular microalgae. CAB 2013 - International on Computer Applications to Biotechnology, Dec 2013, Mumbai, India. ⟨hal-00856042v2⟩
393 Consultations
359 Téléchargements
