Active magnetic bearing: A new step for model-free control - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2013
The newly introduced model-free control is applied to the stabilization of an active magnetic bearing, which is a most important industrial device. Experimental results are compared to those obtained via other control techniques, showing at least on-par performance with this very straightforward approach, which is moreover quite easy to implement.
MagnBearingCDC13.pdf (506.98 Ko) Télécharger le fichier
Dates and versions
hal-00857649 , version 1 (03-09-2013)
Identifiers
  • HAL Id : hal-00857649 , version 1
Cite
Jérôme de Miras, Cédric Join, Michel Fliess, Samer Riachy, Stéphane Bonnet. Active magnetic bearing: A new step for model-free control. 52nd IEEE Conference on Decision and Control, CDC 2013, Dec 2013, Florence, Italy. pp.7449-7454. ⟨hal-00857649⟩
1018 View
2017 Download
Share
