Algebraic Dynamic Programming 2.0 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a--yet unpublished-- generalization of the Algebraic Dynamic Programming framework which also accomodates problems on trees. The new framework is not an "add-on" extension, but suggests a reformulation of "classical" ADP. ADP 2.0 is not only more general, but (arguably) more elegant - and more difficult to implement. In fact, no general implementation technique is known at present. An ensemble of about 30 problems - most classical, some new - from biosequence and structure analysis has been described in the new framework.
hal8_submission.pdf (194.36 Ko) Télécharger le fichier
hal-00857801 , version 1 (04-09-2013)
  • HAL Id : hal-00857801 , version 1
Robert Giegerich, Hélène Touzet. Algebraic Dynamic Programming 2.0. Workshop Haskell-Treffen an der Universität Leipzig, Jun 2013, Leipzig, Germany. ⟨hal-00857801⟩
261 Consultations
158 Téléchargements
