Estimating the Division Rate of the Self-Similar Growth-Fragmentation Equation
We consider the growth-fragmentation equation and we address the problem of finding the division rate from the stable size distribution of the population, which is easily measured, but non-smooth. We propose a method based on the Mellin transform for growth-fragmentation equations with self-similar kernels. We build a sequence of functions which converges to the density of the population in division, simultaneously in several weighted L2 spaces, as the measurement error goes to 0. This improves previous results for self-similar kernels and allows us to understand the partial results for general fragmentation kernels. Numerical simulations confirm the theoretical results. Moreover, our numerical method is tested on real biological data, arising from a bacteria growth and fission experiment.
