Arguing over Goals for Negotiation: Adopting an Assumption-Based Argumentation Decision Support System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Group Decision and Negotiation Année : 2014
Computational models of argumentation has been put forward as a promising approach to support decision making. In this context several recent works have proposed argumentation-based frameworks for decision making. In this paper we describe an application based on an argumentation-based mechanism for decision-making to concede. Adopting the assumption-based approach of argumentation, we propose an argumentation framework in which preferences are attached to goals. Arguments are defined as tree-like structures. Our framework is equipped with a computational counterpart for solving a decision problem, modeling the intuition that high-ranked goals are preferred to low-ranked goals which can be withdrawn. In this way, our framework suggests some decisions and provides an interactive and intelligible explanation of this choice. Our implementation, called MARGO, has been used for service selection within the ArguGRID project. We illustrate our approach with an industrial application, and illustrate the operation of the system with a running example.
hal-00858826 , version 1 (06-09-2013)
Maxime Morge, Paolo Mancarella. Arguing over Goals for Negotiation: Adopting an Assumption-Based Argumentation Decision Support System. Group Decision and Negotiation, 2014, 23 (5), pp.979-1012. ⟨10.1007/s10726-012-9324-4⟩. ⟨hal-00858826⟩
189 Consultations
0 Téléchargements
