Determination of the effect of geological reservoir variability on carbon dioxide storage using numerical experiments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Oil & Gas Science and Technology - Revue d'IFP Energies nouvelles Année : 2013
The simulations of carbon dioxide storage in sedimentary reservoirs model the fluid and gas flow and the chemical reactions which occur between the minerals (calcite and dolomite) and the injected CO2 [André et al. (2007) Energy Convers. Manage. 48, 1782-1797; Gunter et al. (1999) Appl. Geochem. 4, 1-11]. However because of the lack of data, these reservoirs are always partially known and the fitted variograms of petrophysical and mineralogical quantities are approximate. The aim is to quantify the impact of uncertainties on reservoir characteristics on the storage predictions. We focus on two operational parameters: the quantity of the stored carbon dioxide and the mean variation of the porosity. Two sources of uncertainties are examined: the draw dispersion and the approximation on the variogram parameters. To study the influence of the draw dispersion, variogram parameters are kept fixed and different simulations are run; the associated variance on the operational parameters then has the meaning of a repeatability error. In the second case, a sensibility analysis is carried out to study the influence of variogram parameters variations (sill, range, nugget effect) on the CO2 storage. The chosen methodology is the designs of experiments. The simulations are carried out using reactive transport software. The studied carbonated reservoir is built in reference to the Dogger formation of Paris Basin (France) [Diedro (2009) Thèse, École Nationale Supérieure des Mines de St-Étienne]. This reservoir is composed of several minerals, some of them being disposed in spots. The results show that the impact of the draw dispersion remains lower than the impact of the variogram parameters. The effect of the size of the dolomite spots within the rock on the stored carbon dioxide is to be noticed. Larger spots of the dolomite field with low concentration lead to a greater precipitation of carbonate and reduction of porosity than little spots with higher concentrations. The interaction between the sill and the range of the variogram of the initial dolomite concentration is also important. The initial calcite concentration has a slight influence only on the average porosity in the reservoir. Except for the variations of the size of the dolomite spots within the rock, small variations on the variogram parameters of the mineralogical concentration do not involve important modification of stored carbon nor of the final porosity.
Détermination de la variabilité des réservoirs géologiques sur le stockage du CO2 par la méthodologie des plans d'expériences
Dans le contexte de l'étude du stockage géologique du dioxyde de carbone dans les réservoirs sédimentaires, les simulations tentent de reproduire le plus fidèlement possible les écoulements fluides et gaz, ainsi que les réactions chimiques entre les minéraux (calcite et dolomite) et le CO2 injecté [André et al. (2007) Energy Convers. Manage. 48, 1782-1797; Gunter et al. (1999) Appl. Geochem. 4, 1-11]. Cependant, les réservoirs étudiés sont généralement mal connus. Les observations sont peu nombreuses et par suite les variogrammes des propriétés pétrophysiques et minéralogiques sont approchés. L'article vise à quantifier les incertitudes sur les prévisions de stockage du CO2. Nous examinons en particulier l'effet des incertitudes sur deux paramètres opérationnels : la quantité de dioxyde de carbone stockée et la variation moyenne de la porosité. Les sources d'incertitudes retenues sont la variabilité du tirage (dispersion statistique) et l'incertitude sur les paramètres du variogramme. Pour examiner la variabilité liée au tirage, les paramètres du variogramme sont fixés et plusieurs simulations sont réalisées, ce qui fournit une distribution de valeurs pour les paramètres opérationnels et permet le calcul d'une variance, apparentée à une variance de répétabilité. Dans le second cas, une analyse de sensibilité permet d'examiner l'influence des paramètres des variogrammes (palier, portée, effet de pépite) sur le stockage du CO2. À cet effet, la méthodologie des plans d'expériences est utilisée. Les simulations sont réalisées à l'aide d'un logiciel de transport réactif. Le gisement étudié est construit en référence à la formation du Dogger du Bassin de Paris (France) [Diedro (2009) Thèse, École Nationale Supérieure des Mines de St-Étienne]. Les réservoirs simulés comportent plusieurs minéraux avec pour certains des taches de dolomite. Les résultats montrent que la variabilité du tirage reste inférieure à l'effet dû à l'incertitude sur les paramètres du variogramme. L'effet de la taille des taches de dolomite sur le dioxyde de carbone a été également mis en évidence. Les grandes taches à concentration moyenne favorisent une .importante précipitation de carbonate entrainant ainsi une baisse de la porosité moyenne contrairement à des taches plus petites mais à plus forte concentration. L'interaction entre le palier et la portée du variogramme de la dolomite initiale est également importante. La concentration initiale de calcite n'a d'influence que sur la porosité moyenne dans le réservoir et cette influence reste modeste. De petites variations sur les autres paramètres du variogramme de la concentration minéralogique modifient peu le carbone stocké ou la porosité finale.
BG-OGST-Orig.pdf (2.38 Mo) Télécharger le fichier
hal-00859176 , version 1 (06-09-2013)
Frank Diedro, Céline Helbert, Bernard Guy, Chantal de Fouquet. Determination of the effect of geological reservoir variability on carbon dioxide storage using numerical experiments. Oil & Gas Science and Technology - Revue d'IFP Energies nouvelles, 2013, 68 (3), pp.529-544. ⟨10.2516/ogst/2012049⟩. ⟨hal-00859176⟩
470 Consultations
236 Téléchargements
