Easily rendering token-ring algorithms of distributed and parallel applications fault tolerant - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
We propose in this paper a new algorithm that, when called by existing token ring-based algorithms of parallel and distributed applications, easily renders the token tolerant to losses in presence of node crashes. At most k consecutive node crashes are tolerated in the ring. Our algorithm scales very well since a node monitors the liveness of at most k other nodes and neither a global election algorithm nor broadcast primitives are used to regenerate a new token. It is thus very effective in terms of latency cost. Finally, a study of the probability of having at most k consecutive node crashes in the presence of f failures and a discussion of how to extend our algorithm to other logical topologies are also presented.
Autre [cs.OH]
RR-8359.pdf (1021.86 Ko) Télécharger le fichier
hal-00859863 , version 1 (09-09-2013)
  • HAL Id : hal-00859863 , version 1
Luciana Arantes, Julien Sopena. Easily rendering token-ring algorithms of distributed and parallel applications fault tolerant. [Research Report] RR-8359, INRIA. 2013, pp.23. ⟨hal-00859863⟩
253 Consultations
1361 Téléchargements
