A General Procedure for the Construction of Mirror Anamorphoses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Anamorphoses are distorted images needing to be seen from a special point of view in order to reconstruct the correct image (perspectival anamorphosis). In catoptric anamorphosis, a mirror is used to restore the original image. We describe an effective procedure, using a ray-tracer software, for defining, testing and building general catoptric anamorphoses. Users can define the mirror's shape, the surface on which the distorted image lays, and set the observer's point of view. The method can be used to virtually render and test anamorphoses designs or to output a distorted image in any suitable image format that can be printed at any scale, in order to obtain a real size version of the anamorphosis. We exhibit examples with different mirrors and different distorted image locus.
Mots clés
paperBridges2010.pdf (10.21 Mo) Télécharger le fichier
hal-00861388 , version 1 (14-10-2013)
  • HAL Id : hal-00861388 , version 1
Francesco de Comite. A General Procedure for the Construction of Mirror Anamorphoses. Bridges 2010: Mathematics, Music, Art, Architecture, Culture, Jul 2010, Pecs, Hungary. pp.231--238. ⟨hal-00861388⟩
263 Consultations
792 Téléchargements
