A non linear approximation method for solving high dimensional partial differential equations: Application in finance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics and Computers in Simulation Année : 2018
We study an algorithm which has been proposed by Chinesta et al. to solve high-dimensional partial differential equations. The idea is to represent the solution as a sum of tensor products and to compute iteratively the terms of this sum. This algorithm is related to the so-called greedy algorithm introduced by Temlyakov. In this paper, we investigate the application of the greedy algorithm in finance and more precisely to the option pricing problem. We approximate the solution to the Black-Scholes equation and we propose a variance reduction method. In numerical experiments, we obtain results for up to 10 underlyings. Besides, the proposed variance reduction method permits an important reduction of the variance in comparison with a classical Monte Carlo method.
papier_greedy_bs.pdf (343.5 Ko) Télécharger le fichier
hal-00861892 , version 1 (13-09-2013)
hal-00861892 , version 2 (17-09-2013)
José Infante Acevedo, Tony Lelièvre. A non linear approximation method for solving high dimensional partial differential equations: Application in finance. Mathematics and Computers in Simulation, 2018, 143, pp.14-34. ⟨10.1016/j.matcom.2016.07.013⟩. ⟨hal-00861892v2⟩
367 Consultations
498 Téléchargements
