Travelling waves for the cane toads equation with bounded traits. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
In this paper, we study propagation in a nonlocal reaction-diffusion-mutation model describing the invasion of cane toads in Australia. The population of toads is structured by a space variable and a phenotypical trait and the space-diffusivity depends on the trait. We use a Schauder topological degree argument for the construction of some travelling wave solutions of the model. The speed $c^*$ of the wave is obtained after solving a suitable spectral problem in the trait variable. An eigenvector arising from this eigenvalue problem gives the flavor of the profile at the edge of the front. The major difficulty is to obtain uniform $L^\infty$ bounds despite the combination of non local terms and an heterogeneous diffusivity.
Toads-TW.pdf (283.22 Ko) Télécharger le fichier
hal-00863115 , version 1 (18-09-2013)
Emeric Bouin, Vincent Calvez. Travelling waves for the cane toads equation with bounded traits.. 2013. ⟨hal-00863115⟩
167 Consultations
183 Téléchargements
