Learning a Zonotope and More: Cryptanalysis of NTRUSign Countermeasures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
NTRUsign is the most practical lattice signature scheme. Its basic version was broken by Nguyen and Regev in 2006: one can efficiently recover the secret key from about 400 signatures. However, countermeasures have been proposed to repair the scheme, such as the perturbation used in NTRUsign standardization proposals, and the deformation proposed by Hu et al. at IEEE Trans. Inform. Theory in 2008. These two countermeasures were claimed to prevent the NR attack. Surprisingly, we show that these two claims are incorrect by revisiting the NR gradient-descent attack: the attack is more powerful than previously expected, and actually breaks both countermeasures in practice, e.g. 8,000 signatures suffice to break NTRUsign-251 with one perturbation as submitted to IEEE P1363 in 2003. More precisely, we explain why the Nguyen-Regev algorithm for learning a parallelepiped is heuristically able to learn more complex objects, such as zonotopes and deformed parallelepipeds.
DucasNguyen_Learning.pdf (391.74 Ko) Télécharger le fichier
hal-00864359 , version 1 (21-09-2013)
Léo Ducas, Phong Q. Nguyen. Learning a Zonotope and More: Cryptanalysis of NTRUSign Countermeasures. ASIACRYPT 2012 - 18th International Conference on the Theory and Application of Cryptology and Information Security, IACR, Dec 2012, Beijing, China. pp.433-450, ⟨10.1007/978-3-642-34961-4_27⟩. ⟨hal-00864359⟩
488 Consultations
332 Téléchargements
