Adaptive mesh refinement strategy for a nonconservative transport problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2014
Long time simulations of transport equations raise computational challenges since they require both a large domain of calculation and sufficient accuracy. It is therefore advantageous, in terms of computational costs, to use a time varying adaptive mesh, with small cells in the region of interest and coarser cells where the solution is smooth. Biological models involving cell dynamics fall for instance within this framework and are often non conservative to account for cell division. In that case the threshold controlling the spatial adaptivity may have to be time-dependent in order to keep up with the progression of the solution. In this article we tackle the difficulties arising when applying a Multiresolution method to a transport equation with discontinuous fluxes modeling localized mitosis. The analysis of the numerical method is performed on a simplified model and numerical scheme. An original threshold strategy is proposed and validated thanks to extensive numerical tests. It is then applied to a biological model in both cases of distributed and localized mitosis.
ACP_M2AN_HAL.pdf (958.98 Ko) Télécharger le fichier
hal-00865429 , version 1 (24-09-2013)
hal-00865429 , version 2 (19-01-2015)
Benjamin Aymard, Frédérique Clément, Marie Postel. Adaptive mesh refinement strategy for a nonconservative transport problem. ESAIM: Mathematical Modelling and Numerical Analysis, 2014, pp.1381 - 1412. ⟨10.1051/m2an/2014014⟩. ⟨hal-00865429v2⟩
456 Consultations
281 Téléchargements
