Intriguing properties of extreme geometric quantiles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue REVSTAT - Statistical Journal Année : 2017
A popular way to study the tail of a distribution function is to consider its high or extreme quantiles. While this is a standard procedure for univariate distributions, it is harder for multivariate ones, primarily because there is no universally accepted definition of what a multivariate quantile should be. In this paper, we focus on extreme geometric quantiles. Their asymptotics are established, both in direction and magnitude, under suitable integrability conditions, when the norm of the associated index vector tends to one. In particular, it appears that if a random vector has a finite covariance matrix, then the magnitude of its extreme geometric quantiles grows at a fixed rate which is independent of the asymptotic behaviour of the underlying probability distribution. Moreover, in the special case of elliptically contoured distributions, the respective shapes of the contour plots of extreme geometric quantiles and extreme level sets of the probability density function are orthogonal, in some sense. These phenomena are illustrated on some numerical examples.
geoquant_revised.pdf (314.11 Ko) Télécharger le fichier
hal-00865767 , version 1 (25-09-2013)
hal-00865767 , version 2 (12-02-2014)
hal-00865767 , version 3 (26-05-2015)
  • HAL Id : hal-00865767 , version 3
Stéphane Girard, Gilles Stupfler. Intriguing properties of extreme geometric quantiles. REVSTAT - Statistical Journal, 2017, 15 (1), pp.107--139. ⟨hal-00865767v3⟩
574 Consultations
306 Téléchargements
