Leveraging lexical cohesion and disruption for topic segmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Topic segmentation classically relies on one of two criteria, either finding areas with coherent vocabulary use or detecting discontinuities. In this paper, we propose a segmentation criterion combining both lexical cohesion and disruption, enabling a trade-off between the two. We provide the mathematical formulation of the criterion and an efficient graph based decoding algorithm for topic segmentation. Experimental results on standard textual data sets and on a more challenging corpus of automatically transcribed broadcast news shows demonstrate the benefit of such a combination. Gains were observed in all conditions, with segments of either regular or varying length and abrupt or smooth topic shifts. Long segments benefit more than short segments.However the algorithm has proven robust on automatic transcripts with short segments and limited vocabulary reoccurrences.
emnlp.pdf (277.97 Ko) Télécharger le fichier
hal-00867011 , version 1 (27-09-2013)
  • HAL Id : hal-00867011 , version 1
Anca-Roxana Simon, Guillaume Gravier, Pascale Sébillot. Leveraging lexical cohesion and disruption for topic segmentation. International Conference on Empirical Methods in Natural Language Processing, EMNLP 2013, Oct 2013, Seattle, United States. pp.1314--1324. ⟨hal-00867011⟩
355 Consultations
306 Téléchargements
