The Computational Geometry Algorithms Library CGAL - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Communications in Computer Algebra Année : 2013
Efi Fogel
  • Fonction : Auteur
  • PersonId : 855814
Monique Teillaud
The Computational Geometry Algorithms Library (CGAL) is an open source software library that provides industrial and academic users with easy access to reliable implementations of efficient geometric algorithms.
SIGSAM-CCA_2013.pdf (296.24 Ko) Télécharger le fichier
Format : Figure, Image
hal-00867884 , version 1 (30-09-2013)
  • HAL Id : hal-00867884 , version 1
Efi Fogel, Monique Teillaud. The Computational Geometry Algorithms Library CGAL. ACM Communications in Computer Algebra, 2013, Issue 185, 47 (3), pp.85-87. ⟨hal-00867884⟩
Collections
INRIA INRIA2
6857 Consultations
852 Téléchargements
