ARTIST Methodology and Framework: A novel approach for the migration of legacy software on the Cloud - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nowadays Cloud Computing is considered as the ideal environment for engineering, hosting and provisioning applications. A continuously increasing set of cloud-based solutions is available to application owners and developers to tailor their applications exploiting the advanced features of this paradigm for elasticity, high availability and performance. Even though these offerings provide many benefits to new applications, they often incorporate constrains to the modernization and migration of legacy applications by obliging the use of specific development technologies and explicit architectural design approaches. The modernization and adaptation of legacy applications to cloud environments is a great challenge for all involved stakeholders, not only from the technical perspective, but also in business level with the need to adapt the the business processes and models of the modernized application that will be offered from now on, as a service. In this paper we present a novel model-driven approach for the migration of legacy applications in modern cloud environments which covers all aspects and phases of the migration process, as well as an integrated framework that supports all migration process.
ARTISTMethodologyFramework_SYNACS-MICAS2013.pdf (468.32 Ko) Télécharger le fichier
hal-00869276 , version 1 (11-02-2016)
Andreas Menychtas, Christina Santzaridou, George Kousiouris, Theodora Varvarigou, Leire Orue-Echevarria, et al.. ARTIST Methodology and Framework: A novel approach for the migration of legacy software on the Cloud. 2013 15th International Symposium on Symbolic and Numeric Algorithms for Scientific Computing, Sep 2013, Timisoara, Romania. ⟨10.1109/SYNASC.2013.62⟩. ⟨hal-00869276⟩
713 Consultations
924 Téléchargements
