Perfect Conductor and Impedance Boundary Condition Corrections via a Finite Element Subproblem Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Magnetics Année : 2014
A finite element subproblem method is developed to correct the inaccuracies proper to perfect conductor and impedance boundary condition models, in particular near edges and corners of conductors, for a large range of conductivities and frequencies. Successive local corrections, supported by fine local meshes, can be obtained from each model to a more accurate one, allowing efficient extensions of their domains of validity.
hal-00869987 , version 1 (04-10-2013)
Patrick Dular, Victor Péron, Ronan Perrussel, Laurent Krähenbühl, Christophe Geuzaine. Perfect Conductor and Impedance Boundary Condition Corrections via a Finite Element Subproblem Method. IEEE Transactions on Magnetics, 2014, 50 (2), pp.7000504. ⟨10.1109/TMAG.2013.2284338⟩. ⟨hal-00869987⟩
895 Consultations
0 Téléchargements
