Structural Evaluation of AES and Chosen-Key Distinguisher of 9-round AES-128 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
While the symmetric-key cryptography community has now a good experience on how to build a secure and efficient fixed permutation, it remains an open problem how to design a key-schedule for block ciphers, as shown by the numerous candidates broken in the related-key model or in a hash function setting. Provable security against differential and linear cryptanalysis in the related-key scenario is an important step towards a better understanding of its construction. Using a structural analysis, we show that the full AES-128 cannot be proven secure unless the exact coefficients of the MDS matrix and the S-Box differential properties are taken into account since its structure is vulnerable to a related-key differential attack. We then exhibit a chosen-key distinguisher for AES-128 reduced to 9 rounds, which solves an open problem of the symmetric community. We obtain these results by revisiting algorithmic theory and graph-based ideas to compute all the best differential characteristics in SPN ciphers, with a special focus on AES-like ciphers subject to related-keys. We use a variant of Dijkstra's algorithm to efficiently find the most efficient related-key attacks on SPN ciphers with an algorithm linear in the number of rounds.
crypto2013.pdf (722.9 Ko) Télécharger le fichier
hal-00870453 , version 1 (07-10-2013)
  • HAL Id : hal-00870453 , version 1
Pierre-Alain Fouque, Jérémy Jean, Thomas Peyrin. Structural Evaluation of AES and Chosen-Key Distinguisher of 9-round AES-128. CRYPTO 2013, Aug 2013, Santa Barbara, United States. ⟨hal-00870453⟩
230 Consultations
328 Téléchargements
