Complexity of Existential Positive First-Order Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Logic and Computation Année : 2013
Let Γ be a (not necessarily finite) structure with a finite relational signature. We prove that deciding whether a given existential positive sentence holds in Γ is in LOG SPACE or complete for the class CSP(Γ)NP under deterministic polynomial-time many-one reductions. Here, CSP(Γ)NP is the class of problems that can be reduced to the constraint satisfaction problem of Γ under non-deterministic polynomial-time many-one reductions.
expos-final.pdf (105.32 Ko) Télécharger le fichier
hal-00870985 , version 1 (21-10-2013)
Manuel Bodirsky, Miki Hermann, Florian Richoux. Complexity of Existential Positive First-Order Logic. Journal of Logic and Computation, 2013, 23 (4), pp.753-760. ⟨10.1093/logcom/exr043⟩. ⟨hal-00870985⟩
283 Consultations
162 Téléchargements
