Genus 2 Hyperelliptic Curve Families with Explicit Jacobian Order Evaluation and Pairing-Friendly Constructions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The use of (hyper)elliptic curves in cryptography relies on the ability to compute the Jacobian order of a given curve. Recently, Satoh proposed a probabilistic polynomial time algorithm to test whether the Jacobian -- over a finite field $\mathbb{F}_q$ -- of a hyperelliptic curve of the form $Y^2 = X^5 + aX^3 + bX$ (with $a,b \in \mathbb{F}_q^*$) has a large prime factor. His approach is to obtain candidates for the zeta function of the Jacobian over $\mathbb{F}_q^*$ from its zeta function over an extension field where the Jacobian splits. We extend and generalize Satoh's idea to provide \emph{explicit} formulas for the zeta function of the Jacobian of genus 2 hyperelliptic curves of the form $Y^2 = X^5 + aX^3 + bX$ and $Y^2 = X^6 + aX^3 + b$ (with $a,b \in \mathbb{F}_q^*$). Our results are proved by elementary (but intricate) polynomial root-finding techniques. Hyperelliptic curves with small embedding degree and large prime-order subgroup are key ingredients for implementing pairing-based cryptographic systems. Using our closed formulas for the Jacobian order, we present several algorithms to obtain so-called \emph{pairing-friendly} genus 2 hyperelliptic curves. Our method relies on techniques initially proposed to produce pairing-friendly elliptic curves (namely, the Cocks-Pinch method and the Brezing-Weng method). We demonstrate this method by constructing several interesting curves with $\rho$-values around 3. We found for each embedding degree $5 \leqslant k \leqslant 35$ a family of curves of $\rho$-value between $2.25$ and $4$.
hal-00871327 , version 1 (09-10-2013)
Aurore Guillevic, Damien Vergnaud. Genus 2 Hyperelliptic Curve Families with Explicit Jacobian Order Evaluation and Pairing-Friendly Constructions. Pairing-Based Cryptography - Pairing 2012, May 2012, Cologne, Germany. pp.234-253, ⟨10.1007/978-3-642-36334-4_16⟩. ⟨hal-00871327⟩
232 Consultations
0 Téléchargements
