ANOVA decomposition of conditional Gaussian processes for sensitivity analysis with dependent inputs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Statistical Computation and Simulation Année : 2015
Complex computer codes are widely used in science to model physical systems. Sensitivity analysis aims to measure the contributions of the inputs on the code output variability. An efficient tool to perform such analysis are the variance-based methods which have been recently investigated in the framework of dependent inputs. One of their issue is that they require a large number of runs for the complex simulators. To handle it, a Gaussian process regression model may be used to approximate the complex code. In this work, we propose to decompose a Gaussian process into a high dimensional representation. This leads to the definition of a variance-based sensitivity measure well tailored for non-independent inputs. We give a methodology to estimate these indices and to quantify their uncertainty. Finally, the approach is illustrated on toy functions and on a river flood model.
kernelANOVA.pdf (347.27 Ko) Télécharger le fichier
hal-00872250 , version 1 (11-10-2013)
Gaëlle Chastaing, Loic Le Gratiet. ANOVA decomposition of conditional Gaussian processes for sensitivity analysis with dependent inputs. Journal of Statistical Computation and Simulation, 2015, 85 (11), pp.2164-2186. ⟨10.1080/00949655.2014.925111⟩. ⟨hal-00872250⟩
551 Consultations
795 Téléchargements
