An Attempt at Classifying Homogenization-Based Numerical Methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Continuous Dynamical Systems - Series S Année : 2015
In this note, a classification of Homogenization-Based Numerical Methods and (in particular) of Numerical Methods that are based on the Two-Scale Convergence is done. In this classification stand: Direct Homogenization-Based Numerical Methods; H-Measure-Based Numerical Methods; Two-Scale Numerical Methods and TSAPS: Two-Scale Asymptotic Preserving Schemes.
FrClassTSNM.pdf (112.97 Ko) Télécharger le fichier
hal-00872394 , version 1 (12-10-2013)
Emmanuel Frenod. An Attempt at Classifying Homogenization-Based Numerical Methods. Discrete and Continuous Dynamical Systems - Series S, 2015, Numerical Methods Based on Two-Scale Convergence and Homogenization, 8 (1), pp.6. ⟨10.3934/dcdss.2015.8.1i⟩. ⟨hal-00872394⟩
564 Consultations
251 Téléchargements
