Two-Scale numerical simulation of sand transport problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Continuous Dynamical Systems - Series S Année : 2015
In this paper we consider a model for short term dynamics of dunes in tidal area. We construct a Two-Scale Numerical Method based on the fact that the solution of the equation which has oscillations Two-Scale converges to the solution of a well-posed problem. This numerical method uses on Fourier series.
numerictransableVdcds50.pdf (2.5 Mo) Télécharger le fichier
hal-00873012 , version 1 (14-10-2013)
Emmanuel Frenod, Ibrahima Faye, Diaraf Seck. Two-Scale numerical simulation of sand transport problems. Discrete and Continuous Dynamical Systems - Series S, 2015, Numerical Methods Based on Two-Scale Convergence and Homogenization, 8 (1), pp.151--168. ⟨10.3934/dcdss.2015.8.151⟩. ⟨hal-00873012⟩
495 Consultations
242 Téléchargements
